1. anon(10012551)'s Avatar
    I'm talking about the loud beeping sound every time I click on the camera to focus. Not only is it loud, it's not at all practical to take photos in certain places, i.e an art gallery, churches. I know there is a solution for rooted Android, but is there any other way to get rid of it?
    I always have the sound from the radio and the apps off, only alarm is left at max.
    My phone is a Wiko Ridge 4G, w/ Lollipop 5.0.2. If the answer is no, what is the best free camera option for this, with similiar funcionability? It seems rather silly that I have to change to another app, and reduce the quality and settings I could have if not for this loud noise.
    10-02-2016 01:24 PM
  2. B. Diddy's Avatar
    If you open the Camera app and go to its settings, is there an option to turn off the shutter sound? If you can do that, then I would guess that the autofocus beep would also be muted.
    10-02-2016 05:45 PM
  1. Play store seems crappy..unable to install apps...
    Last Post: 10-20-2016, 04:44 PM
  2. Control 6P Camera with Macbook?
    By jimhuntphoto in forum Nexus 6P
    Last Post: 10-03-2016, 01:09 AM
  3. Replies: 1
    Last Post: 10-02-2016, 03:05 PM
  4. All I want to do is remove picassa pics, I deleted Google +
    Last Post: 10-02-2016, 02:04 PM
  5. Replies: 1
    Last Post: 10-02-2016, 01:53 PM
