1. whmdan's Avatar
    I still own a note 4, primarily because I'm poor, but also because I enjoy it. I enjoy the interchangeable battery ability, something Samsung and Apple seem to be done with. I enjoy the 10,000 mah battery I use in place of the OEM battery. That said, I am sick and tired of battery notifications. I pretty much hate all notifications, especially the invasive ones like these. I'd like to never see another battery notification ever, least of all these new ones which ask if I want to turn off wifi and such. The answer will always be no. These more invasive battery messages started after I did a factory reset. Prior to the reset, I only recieved two notifications, which didn't ask about wifi or vibration. I'd prefer no notifications, but I'll settle just to ditch the newly added ones. I have tried various techniques found in other posts. I have linked screenshots to save people time. Please see the screenshots below: (the screenshots are to show the options I seem to be missing, which others have suggested to use)
    Attached Thumbnails How to disable all battery notifications (Note4)-screenshot_2017-06-10-19-22-50-1.png   How to disable all battery notifications (Note4)-screenshot_2017-06-10-19-16-06.jpg   How to disable all battery notifications (Note4)-screenshot_2017-06-10-19-15-28.jpg   How to disable all battery notifications (Note4)-screenshot_2017-06-10-19-15-20.jpg
    06-11-2017 11:37 PM
  2. whmdan's Avatar
    Hello? Help please.
    06-20-2017 03:07 AM
  3. whmdan's Avatar
    Does anyone have an answer?
    06-21-2017 03:06 AM
  4. L0n3N1nja's Avatar
    Are you getting a regular notification you need to dismiss from the notification panel or is it the pop up that appears on the screen about low battery? I still have my Note 4 at home, don't use it anymore but I can take a look at it later this week when I've got time and try to figure it out.
    06-21-2017 04:53 AM
  5. whmdan's Avatar
    Thank you for your reply and interest in helping me. It's two different pop-ups. Usually just one, but sometimes both. I'm linking screenshots. The top pop-up notification is the problem. The top one pops up nearly non-stop at times. It's very unpredictable. The other pop up is only at 15% and 5%. So I know when to expect it. I mainly want to be rid of the top one, but if I can disable both, that would be even better.
    Attached Thumbnails How to disable all battery notifications (Note4)-screenshot_2017-06-13-21-14-53.jpg   How to disable all battery notifications (Note4)-screenshot_2017-06-13-21-44-58.jpg
    06-21-2017 06:37 PM
  6. whmdan's Avatar
    Does anyone have a fix for this? Please help.
    07-02-2017 03:04 PM
  7. whmdan's Avatar
    I'm somewhat disappointed nobody has a fix for this.
    07-11-2017 04:36 AM
  1. Color is messed up, how reset to original
    Last Post: 09-15-2018, 05:14 AM
  2. Unable to force stop bluetooth
    Last Post: 06-14-2017, 05:31 PM
  3. How to stop my S8+ from killing recent apps
    By dejanh in forum Samsung Galaxy S8 & S8+
    Last Post: 06-12-2017, 08:00 AM
  4. How can active dot viewer in HTC DESIRE 728 ,
    Last Post: 06-11-2017, 11:22 PM
  5. How to stop bluetooth automatically connecting to devices
    Last Post: 06-11-2017, 11:21 PM
