1. joel567's Avatar
    I have a lg g stylo and i'm trying to free up my space but my internal storage is 2.47 gigabytes available. My miscellaneous is 4.53 gigabytes. I try to free it up and it only cleans up to 6.72 megabytes. It says I can't free up system storage.I have a 32gb sd card inserted with 28.81 gb available. How do I free it up thank you.
    08-29-2017 08:18 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! "Miscellaneous" doesn't mean that data can be safely deleted. It's likely important data for the system or for your apps.
    See this guide for tips on maximizing your internal storage: http://forums.androidcentral.com/amb...-warnings.html. Your phone only has 8 GB of total internal storage, of which 4-5 GB is probably taken up by the system and preinstalled bloatware. 8 GB is basically too little internal storage these days for users you want to install more than just the very basic apps -- you need a phone with at least 16 GB at a bare minimum.
    Your SD card is intended for storage of media files and document files only. I don't believe LG supports Adoptable Storage (i.e., formatting the card to be recognized as part of Internal Storage -- and besides, that's a Marshmallow feature, not Lollipop). You could see if the phone supports the Move to SD function (which moves a portion of an app to the SD), but not all phones do. Go to Settings>App, select some apps, and see if there's a "Move to SD" button.
    08-29-2017 12:11 PM
  1. Wi-Fi problems after update v20i
    By washburn_it in forum LG G5
    Last Post: 10-09-2017, 05:17 AM
  2. Any S8 users having problems with Gboard voice typing working?
    By Chris5483 in forum Samsung Galaxy S8 & S8+
    Last Post: 09-06-2017, 12:53 PM
  3. My stoarage running out due to miscellaneous storage
    Last Post: 08-29-2017, 12:50 PM
  4. how do i hook up corded earphones
    Last Post: 08-29-2017, 12:15 PM
  5. Problem with my personal contact
    Last Post: 08-29-2017, 12:51 AM
