1. hakerdroid95's Avatar
    Hi. I'm new here, but let me just explain what's going on. I have a LG Treasure, and everytime I plug in a wired pair of headphones, it says "We're lowering your media and call volume to protect you're hearing." Well, when I have headphones plugged in, I can get that. But I shouldn't be forced to have the volume at such a low level, and have to turn up my stereo all the way to 100 when I listen to internet radio which I stream on my phone to my stereo through a aux input. It starting to tick me off really really bad. And I don't know what to do.
    06-29-2018 09:27 PM
  2. Mooncatt's Avatar
    There isn't much you can do, as this is built into the OS itself. I don't know the exact story, but it seems to be due to a European regulation and now most manufacturers include this nagging feature across the board. I had some luck with this app. It wasn't 100%, but it cut that nag message out quite a bit.
    https://play.google.com/store/apps/d...d.hearingsaver
    hakerdroid95 likes this.
    06-29-2018 09:46 PM
  3. hakerdroid95's Avatar
    Thanks! It worked well! I had to delete two apps to install the app, but other than that, it works like a charm!
    Mooncatt likes this.
    06-30-2018 11:40 AM
  1. Replies: 6
    Last Post: 06-28-2019, 07:37 AM
  2. i want to reverse the new update its sucks
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 10-04-2018, 12:32 PM
  3. Is there a way to manually choose frame rate when capturing video?
    Last Post: 06-30-2018, 01:12 PM
  4. Why can I not set individual text tones to my contacts?
    Last Post: 06-30-2018, 01:09 PM
  5. Volume rocker issues?
    By eljeffe58 in forum Huawei Mate 10 & Mate 10 Pro
    Last Post: 06-29-2018, 08:49 PM
