Battery Percentage Drop Suddenly
Iamnishanta
17
My battery is really performing weird since a month.
Battery percentage drops suddenly when I turn on my phone after sleep.
Suppose, I turn off my phone at 80% and I turn it back on after an hour, the battery will suddenly drop to 76% and it will remain at that percentage for 30-40 mins.
This problem occurs even during airplane mode or when the phone is switched off.
I have tried
• discharging to 0% and charging to 100%
• factory reset from settings 4 times
• battery calibration app
But nothing seems to work
And the best thing is that my battery usage is more or less still the same as I am getting 10 hour Screen On Time on average.
There's no problem with my network strength... Here's my battery stats, from stock and gsam. Screenshot_2018-07-03-08-36-56.jpgScreenshot_2018-07-03-08-36-52.jpg
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,569
4,700
113
Welcome to Android Central! I don't have a direct answer for you, but I would say that 10 hours of screen on time is unusually high, so whatever you're doing, don't change anything!;)
Iamnishanta
17
Yeah, it's a 4000mah battery, and the battery is working just as well as it was 2 years before, but the problem is the battery percentage reading.
pierre5463
