1. Iamnishanta's Avatar
    I don't know what the second one is called.. but it is available when the phone is off.
    07-06-2018 01:38 AM
  2. B. Diddy's Avatar
    If you're talking about the Wipe Data/Factory Reset option in the Recovery Menu, they're they same.
    Iamnishanta likes this.
    07-06-2018 02:18 AM
  3. Iamnishanta's Avatar
    Yes, the recovery menu
    07-06-2018 05:35 AM
  4. Iamnishanta's Avatar
    Thanks
    07-06-2018 05:35 AM
  5. Iamnishanta's Avatar
    Even doing that won't help me with the battery stats inaccuracy.
    07-06-2018 05:37 AM
  6. Mike Dee's Avatar
    How do you know?
    07-06-2018 06:43 AM
  7. Iamnishanta's Avatar
    Didn't*
    It didn't help me.
    07-06-2018 06:44 AM
  8. Mike Dee's Avatar
    It didn't help me.
    OK
    07-06-2018 06:55 AM
  9. Iamnishanta's Avatar
    OK
    But could you suggest me some solution?
    07-06-2018 06:56 AM
  10. Iamnishanta's Avatar
    OK
    This is the problem: https://forums.androidcentral.com/sh...d.php?t=896694
    07-06-2018 06:57 AM
  11. Mike Dee's Avatar
    You battery is two years old.... That's probably the problem
    07-06-2018 09:25 AM
  12. Iamnishanta's Avatar
    It still gives me 9-11 hour Screen On Time.. the problem is with wrong battery stats and battery percentage.
    07-06-2018 09:30 AM
  13. Mike Dee's Avatar
    What you are experiencing could be caused by an old battery.
    07-06-2018 09:33 AM
  14. Iamnishanta's Avatar
    I still don't know.. anyway, thanks for responding.
    07-06-2018 09:34 AM
  15. B. Diddy's Avatar
    Your phone isn't rooted, right?
    07-06-2018 02:19 PM
  16. Iamnishanta's Avatar
    No..not rooted. Should I root it?
    07-08-2018 10:07 PM
  17. B. Diddy's Avatar
    No, just trying to rule out possible causes. For further discussion about your battery question, refer to your other threads, which I merged here: https://forums.androidcentral.com/ge...ndication.html
    07-09-2018 10:57 AM
  1. what i do touchwiz stop working
    Last Post: 07-06-2018, 01:34 AM
  2. How can i get my pictures and videos back?
    Last Post: 07-06-2018, 12:01 AM
  3. Android Studio: Add badge notification that displays missed calls
    By Android Central Question in forum Software Development and Hacking
    Last Post: 07-05-2018, 11:58 PM
  4. Android Studio: Add badge notification that displays missed calls
    Last Post: 07-05-2018, 11:55 PM
  5. I want to change my default city in acu weather app on Techno Camon X
    Last Post: 07-05-2018, 11:06 PM
