1. Sam1224's Avatar
    Nexus 6 Marshmallow 6.0 Build MRA58K
    Since the update a week ago, my phone has inexplicably begun randomly vertically splitting the display. Usually happens when scrolling through my twitter feed, but it has also happened while using a couple other apps. I've tried capturing screen shots of it when it happens but the screen shots appear normal once I reboot and can go look at them.
    In Twitter, the screen will appear split precisely down the middle and will not sync back up. If I navigate to the home screen, it appears in quadrants. Functionality is there (to reboot the phone via widget) if I choose the correct quadrant and a reboot is the only thing that seems to remedy this.
    It doesn't crash the phone or generate a bug report, it will happily sit like that for a couple hours if I leave it alone. Has anybody seen anything like this before? Any idea on a fix?
    10-22-2015 09:30 AM
  2. Sam1224's Avatar
    Forgot to note that I have had the phone since June and never experienced this issue under Lollipop.
    10-22-2015 09:37 AM
  1. Compass issues, how can I fix it?
    By riskay in forum Nexus 5X
    Last Post: 08-14-2017, 01:02 PM
  2. Screen/Power Button/Security Issues after Software Update
    By Cellidor in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 10-24-2015, 07:09 AM
  3. Insufficient Storage Problem - Not Usual Issue
    Last Post: 10-22-2015, 09:05 AM
  4. Finger print Issues
    By Grantxhenry in forum Ask a Question
    Last Post: 10-22-2015, 08:35 AM
  5. Touch screen issues in some white devices
    By Javier P in forum Sony Xperia Z5 & Z5 Compact
    Last Post: 10-22-2015, 08:22 AM
