1. kaigani's Avatar
    Previously, when headphones were plugged in, media players would display an 'unsafe volume' alert if you turned the volume above 40%
    Since upgrading to Marshmallow, all of my apps are unable to override the 40% volume limit. Any attempt to raise the volume, even with the volume button, and it just resets to 40% again.
    This is very frustrating, considering I can't hear media on the train commute – which is the primary use for my Android device.
    10-27-2015 07:29 AM
  2. ptkelly's Avatar
    I've never noticed a percentage reading but I had two Bluetooth earphones. One gave me an adequate volume--I'm quite deaf--and the other didn't. So, I gave the low volume earphones to a nephew in the hopes he won't go deaf, too. Perhaps your problem is the earphone.
  3. ptkelly's Avatar
    10-27-2015 09:09 AM
  4. kaigani's Avatar
    It's not the earphones.
    This is a screenshot from the VLC media player, which is also how I read the 40% volume level. You can see the slider just won't go above that level no matter what I try. It's the same for other media players.
    Nexus 5: Headphones media volume will not exceed 40% since Marshmallow update-screenshot_20151027-172232.jpg
    10-27-2015 12:26 PM
  5. triksus's Avatar
    I've had the exact problem with my Nexus 7 (2013) after upgrading to Marshmallow. Any solution for this?
    11-28-2015 12:13 PM
  6. Gary Player's Avatar
    Ya this is complete b.s. same thing on my LG GPAD at t dosent have a clue called 7x was told hardware issue when its clearly software issue jus gonna bash the thing off the wall
    05-04-2016 10:29 PM
  1. Photos Not Rotating When I Turn My Phone
    By charitytowin in forum Samsung Galaxy S6
    Last Post: 10-27-2015, 01:14 PM
  2. Nexus 5 losing time even if it is set manually!
    Last Post: 10-27-2015, 08:39 AM
  3. Inbuilt memory is not showing for Lenovo K900
    Last Post: 10-27-2015, 06:44 AM
