1. AC Question's Avatar
    Last summer, when new, my Nexus 6 with Lollipop had wonderful phone call quality. Not now with Marshmallow.
    Is there some kind of app that would smooth out the ragged speech?
    01-20-2016 11:35 PM
  2. Tom Egan's Avatar
    Turned out to be a fairly simple fix. The Project Fi Help person walked me through the process of clearing data and cache in the Project Fi app. I don't know what that did to the system, but all the dropouts are gone now.
  3. B. Diddy's Avatar
    Welcome to Android Central! Is the call quality also bad when using a wired or Bluetooth headset? Are you sure it isn't a problem with the network? Check with your carrier. Make sure any option for HD Calling/Advanced Calling/VoLTE is turned on, if at all possible. If the phone is capable of wi-fi calling, try toggling that on or off, depending on what it's set to right now.
    01-21-2016 12:40 PM
  4. Tom Egan's Avatar
    Thanks for your ideas. I just don't know enough about the technology. I'm going to have to throw myself on the mercy of Help at Google Project Fi which I'm using. It's a beta test, so maybe I'm caught up in some geeky problem that I don't have a chance of solving. (My old flip phone didn't have this problem from this location.)
    01-21-2016 06:54 PM
  5. Tom Egan's Avatar
    B. Diddy likes this.
    01-21-2016 07:26 PM
  1. Why Can't My Phone Synch My Contacts After Upgrade to 5.1.1?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 01-22-2016, 10:28 AM
  2. Nexus 5, Unable to go past welcome screen.
    Last Post: 01-21-2016, 12:48 PM
  3. Replies: 1
    Last Post: 01-21-2016, 12:42 PM
  4. Replies: 1
    Last Post: 01-21-2016, 01:24 AM
  5. Phone dead in 6 hours..Please Help! What should I do?
    By Nriggi15 in forum General Help and How To
    Last Post: 01-20-2016, 10:46 PM
