1. jmarkey77's Avatar
    Hello all,
    I haven't seen this issue anywhere else and googling didn't get me any results. Ever since the Marshmallow upgrade when I open an app that requires data like this app, YouTube, anything else about a 3rd of the time it errors out saying no data or internet. The error varies depending on the app. I chose the app and reopen it and everything is fine.
    This happens on cellular data and WiFi with the same frequency and a factory reset hasn't solved it.
    Ideas?
    02-03-2016 10:33 AM
  2. David Alfredo's Avatar
    Hello all,
    Ideas?
    which version of Android were you using before the M upgrade ? I guess 5.1.1 since it's Nexus, well I would try using data from a different carrier (ask a friend for a SIM) and check, it's really a weird bug and if factory reset didn't solve it I believe it's either the device or the carrier you're using. Apart from that I'm quite surprised with the amount of issues Marshmallow upgrades are bringing to the table considering upgrading from 5.x.x should be not that hard.
    02-03-2016 10:55 AM
  1. Replies: 6
    Last Post: 02-25-2016, 09:38 AM
  2. Why won't my Nexus 7 4.3 recognize my bluetooth keyboard?
    By AC Question in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-10-2016, 10:55 AM
  3. Foldersync marshmallow warnings
    By sswitzer in forum LG G4
    Last Post: 02-09-2016, 12:05 PM
  4. o2 marshmallow in UK.
    By Fixiebo1983 in forum Android 6.0 Marshmallow
    Last Post: 02-03-2016, 02:32 PM
  5. Samsung Note 8.0 charging problems, what can I do to fix them?
    By AC Question in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 02-03-2016, 09:24 AM
