1. Lammo's Avatar
    Ever since updating my LG 4 on Verizon to Marshmallow the volume on the device has decided to randomly adjust itself. I am in court for hours at a time and always turn my volume down. Several times I have found that the device has turned its volume back up. So far it has only sounded once and, thankfully, I was out in the hallway but this is beyond annoying (there are some judges who will confiscate any phone that rings). Anyone else having a similar issue?
    03-02-2016 10:16 AM
  2. N4Newbie's Avatar
    Have you tried using "Do Not Disturb" mode instead? It's really much more effective.
    https://support.google.com/nexus/answer/6111295?hl=en
  3. N4Newbie's Avatar
    03-02-2016 11:11 AM
  4. Lammo's Avatar
    Does not appear to be available on my LG G4 (your link applies to Nexus devices as best I can tell).
    I have started turning the volume control down to "silence" but I don't know if I can trust that either. If I turn the volume all the way down and don't touch the volume keys shouldn't the volume stay where I set it? Also, it seems that I don't get vibration notices of text messages or incoming calls when turned all the way down.
    03-02-2016 07:03 PM
  5. N4Newbie's Avatar
    Interesting. I assumed that it applied to Marshmallow in general.
    03-03-2016 08:08 AM
  1. Replies: 23
    Last Post: 07-31-2018, 10:24 AM
  2. Replies: 5
    Last Post: 09-10-2016, 03:46 AM
  3. Changing night clock to display on the left edge
    By bhatech in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 07:47 AM
  4. Why does my Samsung Galaxy S3 say restricted access changed?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 03-02-2016, 11:31 AM
