1. mohebeffat's Avatar
    I heard rumors about updating OTA does not download the complete release & make some bugs.
    03-23-2016 12:07 PM
  2. Rukbat's Avatar
    OTA has always had a problem - it can break in the middle.
    Smart Switch is the same thing using different hardware.
    If you bring it to your carrier (to a store that actually does work on the phones), they can update it from a file they have with no problem.
    03-23-2016 01:55 PM
  3. mohebeffat's Avatar
    Is it preferable to upgrade using smart switch ot it is better to wait the OTA in case that it may have some bugs issue can be maintatined in the OTA version & Is it void the warranty ? Thanks in advance.
    03-24-2016 08:54 AM
  4. Rukbat's Avatar
    Smart Switch IS OTA, it's just using a different program to do it, so both aren't preferable. OTA just means that you get the update file over the air - whether you get it using the update program in the phone or the update program in Smart Switch makes no difference, if the download is bad [because some of the data downloaded didn't get to you properly], you're updating with a bad download.)
    Neither voids the warranty, but if the update hangs, the phone has to be brought or sent in for repair. If the carrier does it with a non-OTA file, they've used the same file before, so it works, so it won't cause the problem.
    03-26-2016 08:00 PM
  1. Replies: 1
    Last Post: 03-23-2016, 08:11 PM
  2. Not able to transfer full apps to sd card on galaxy s7
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-23-2016, 03:44 PM
  3. transferring apps to sd card proving very difficult.
    By wickedjermany in forum Samsung Galaxy S7 edge
    Last Post: 03-23-2016, 03:23 PM
  4. how do i unlock my logic x4.5 screen foget the code
    Last Post: 03-23-2016, 01:19 PM
  5. Not able to transfer full apps to sd card on galaxy s7
    Last Post: 03-23-2016, 12:42 PM
