1. emjey's Avatar
    Hello, I am using Lenovo k3 note and from today I find a strange behavior where, when I receive any call or text, the notification tray gets hidden.
    When I receive a text, the notification tray hides for 4 sec and reappears
    When I receive a call, it doesn't show me the caller directly, i have to pull down the hidden notification tray and there I see the call notification.
    Anyone facing this? Any fix ? Pls help
    03-27-2016 08:07 AM
  2. N4Newbie's Avatar
    Are you using a third-party notification/light manager such as Light Flow or Light Manager?
    If yes, disable it and see if that resolves the problem.
    03-27-2016 08:41 AM
  3. N4Newbie's Avatar
    And, for what it is worth, I tend to reserve words like "URGENT!" for things like heart attacks and terrorist activity.
    emjey likes this.
    03-27-2016 08:43 AM
  4. emjey's Avatar
    Dude. I can't even see whose calling. Neither name or number appears even if I pull down the tray. Only the phone rings. Doesn't this deserve urgency? :P.
    And yeah, after tons or research found that the DU battery saver had access to control my notification center and thus was blocking it. After cutting it's access, the notifications now are back to normal.
    Thanks.
    And yeah? Are help regarding heart attack and terrorist activity encouraged here? M amazed
    03-27-2016 08:57 AM
  5. N4Newbie's Avatar
    Battery savers usually do more harm than good. Notification managers have all sorts of problems and often go through a new round of issues with each new OS update.
    It is a wise man who avoids both.
    emjey likes this.
    03-27-2016 09:13 AM
  6. emjey's Avatar
    So you mean to say that using battery saver will actually suck up more battery and also create performance issues?
    03-27-2016 01:33 PM
  1. Replies: 7
    Last Post: 07-10-2017, 07:31 PM
  2. help with moto g2 wont start
    By surjeet marwah in forum Moto G (2014)
    Last Post: 03-27-2016, 05:41 PM
  3. Android 6.0.1 Marshmallow for galaxy s6 Australia?
    By AliVardz in forum Samsung Galaxy S6
    Last Post: 03-27-2016, 11:52 AM
  4. folders missing from SD card when using android file transfer
    Last Post: 03-27-2016, 10:41 AM
  5. my phone general mobile 4G android one has a problem..
    Last Post: 03-27-2016, 06:55 AM
