1. Cychou's Avatar
    Curtently when activating the battery percentage display, the percentage is displayed inside the battery logo, and the numbers are quite difficult to read.
    I suggest to move the percentage just next to the battery logo, allowing to get a little bigger percentage numbers size.
    06-08-2016 04:21 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I agree, the battery percentage feature in the System UI Tuner is fairly useless. I use Power Toggles, which has an option to show the current battery in large digits in the status bar.
    Not sure if you realize this, but we're an independent community forum, and aren't directly affiliated with Google. Thanks!
    06-08-2016 05:43 PM
  3. ptkelly's Avatar
    I use the Transparent Weather App, which I like anyway, and it shows my batter level large enough for me to read.
    06-09-2016 12:06 PM
  1. Why is my memory card can't show the file?
    By tashadjimun in forum Memory (RAM)
    Last Post: 08-09-2016, 07:21 AM
  2. Using the S7 Edge, without the Edge
    By teeitupmo#WN in forum Samsung Galaxy S7 edge
    Last Post: 06-13-2016, 04:16 AM
  3. 28GB on sd card, yet I can't move movable apps to the card
    Last Post: 06-12-2016, 02:36 PM
  4. Phones without the navigation bar
    Last Post: 06-09-2016, 06:17 AM
  5. My moto x 2nd genration battery stuck at 66% while charging
    Last Post: 06-08-2016, 02:57 AM
