After upgrading to 6.0.1 My S7 Edge lost Voice Recognition
Bugwart
16
Up until the upgrade to 6.0.1, I could choose to either enter text from the keyboard or by voice recognition.
The microphone icon that used to be on the lowest row of the keyboard is gone.
Thanks,
:eek:
SpookDroid
Ambassador
Jul 14, 2011
19,298
555
113
Are you using the stock keyboard? If so, there should be a gear icon in your keyboard...if you tap and hold that it should give a pop up with more options (emoji, handwriting recognition, etc.), including the voice recognition option. After using that once, that should become the 'default' button to show up. If you use any other, however, that new option will become the default (basically whatever you used last will show up there).
Finsrepair
