1. slobkabob's Avatar
    Prior to the Marshmallow update I could adjust my Ringtone using the volume buttons on the side of my Note 5, but now they only control Media volume. Is there a way to change it back to controlling Ringtone volume?
    06-30-2016 10:03 AM
  2. B. Diddy's Avatar
    If an app is open that is currently playing media, then it should default to controlling Media volume. If nothing is currently playing media, then it should control Ringtone volume. Are you saying that even when your phone is doing nothing, the volume buttons still only control Media?
    06-30-2016 12:33 PM
  3. slobkabob's Avatar
    Issue is resolved. I did try closing all apps but the issue persisted until I did a restart. Makes no sense as to why a restart worked when all apps being closed didn't.
    B. Diddy likes this.
    06-30-2016 01:40 PM
  4. B. Diddy's Avatar
    Glad you figured it out. How were you closing apps? Next time this happens, go to the App Manager, then Running Apps, and see what is currently open in RAM. (Running App might be in a different location on your phone--this is something manufacturers sometimes move around in the settings menu.)
    06-30-2016 04:33 PM
  1. Bluetooth volume control gone
    By pjw23 in forum Samsung Galaxy S7 edge
    Last Post: 07-05-2016, 10:25 AM
  2. Bluetooth audio volume issues
    By EmberMelodica in forum Samsung Galaxy S7
    Last Post: 07-02-2016, 10:30 PM
  3. Texts Coming in Out of Order - Time Set on Manual
    Last Post: 06-30-2016, 09:43 AM
  4. Replies: 0
    Last Post: 06-30-2016, 09:02 AM
  5. Replies: 1
    Last Post: 06-30-2016, 08:58 AM
