1. Hotpl4te's Avatar
    Hi guys.
    I have an HTC One M8. Previously I had an M7.
    The M8 has developed bluetooth issues since upgrading to MM 6.0 earlier this year. Basically it connects to my car but not for long. Less than 5 minutes. The car is a Volvo S60 with Senus Connect.
    I have had Volvo replace the Senus Connect under warranty at £2500 , and the issue still remains !!!! So my phone no longer works in the car anymore. It used to , but the length of time it worked in the car reduced from many hours a day, to just a few minutes before crashing.
    I am wondering if MM 6.0.1 would fix this issue? How would I go about put that on my phone when HTC haven't released it as an upgrade, and lets be honest - its not coming is it. My phone is now considered way too old for that upgrade. Probably will not get N either.
    Does anyone have any suggestions with regards putting 6.0.1 on there?
    Thanks in advance
    07-24-2016 04:07 AM
  2. N4Newbie's Avatar
    It crashes? As in, you get a popup error/crash report? What does it say?
    Which music (I assume) player app are you using? Does the same thing happen when using another app?
    07-24-2016 07:13 AM
  3. Hotpl4te's Avatar
    No Sorry I have not explained this very well. The Sensus Connect in the car hangs and then restarts itself.
    The reason is to do with Bluetooth not being able to make a full connection. It says in settings (no media). And it keeps trying to connect fully to the car, but ultimately fails.
    This only started after upgrade to MM 6.0.
    I have tried an S7 on 6.0.1 and this was perfect.
    07-24-2016 04:51 PM
  4. 4uncavan's Avatar
    I am in 6.0.1 and I have the same issue in my 2013 Toyota Camry Hybrid.
    I'm desperate for a fix.
    N4Newbie: Error in car says "Lost connection to Pandora. Check your internet connection and try again." Phone says it is connected. Car says Bluetooth is off, and I cannot turn it on again in Settings.
    07-27-2016 02:11 PM
  1. [Advance 5.0] can't factory reset due to keyboard not appearing
    By diggy boo in forum Blu Android Phones
    Last Post: 07-24-2016, 01:01 PM
  2. Replies: 1
    Last Post: 07-24-2016, 05:24 AM
  3. why my lenovo tab 2 is stocking on systeme recovery ?
    Last Post: 07-24-2016, 04:05 AM
  4. how can i solve authentisation problem to whatsappl
    Last Post: 07-24-2016, 04:01 AM
  5. Replies: 0
    Last Post: 07-24-2016, 03:58 AM
