I am having a ton of issues all at once here. Here's the major ones:
My phone's home and recent apps buttons don't work.
The notification bar doesn't show any notifications and I can't get to my quick settings.
The phone restarts every 30 seconds or so. (It doesn't do this in safe mode, so it may be an unrelated issue to the rest of this)
The lock screen doesn't appear at all. If I set a lock code then apps like Google Now act like the phone is locked, if I set no lock screen then they don't, but no matter what I do I can't get the lock screen to appear.
Google Now on Tap doesn't work.
The phone is stuck in charging only mode via USB because someone at Google decided that was a wise decision. I can't set it to MTP using the notification bar because the notification bar isn't working. I can't enable developer options, probably for the same reason the home button isn't working, and the option to change USB modes in the storage section of the settings menu is gone, so I have no way whatsoever to transfer my data off my phone before doing a factory reset.
I've seen online a lot of people with similar issues in Marshmallow on many different devices but I have yet to see a fix other than a factory reset, but if I do that I lose all my data and what's to stop this from happening again?
