1. whitenote4's Avatar
    I m using Sm N910T and I m on the stock marshmallow rom 6.0.1 N910TUVS2EPG2
    I m really sick of this update
    I have this issue of severe battery drain by two main culprits at Number one it's MEDIA
    and number two is ANDROID SYSTEM. I have already cleared cache using recovery and cleared data in settings. Have checked most of my pics and videos. My battery won't last more then 4 hrs. I have disabled most of the bloat apps and quite a bit of Samsung apps. Sync is @ manual
    Android system cpu usage after a whole day typically is around 6 hrs
    Media cpu usage usually is around 5.30hrs
    Searched through the net and found no real fix for the battery drain
    P.S - I DID THE FACTORY DATA RESET 1 2 TIMES.
    Please help
    08-08-2016 11:26 PM
  2. whitenote4's Avatar
    Please help
    08-08-2016 11:27 PM
  3. shadavis08's Avatar
    Marshmallow is crazy battery hog. Something gets stuck and the phone will get very hot and sometimes start shutting down. This happens with my LG G4 often.
    08-11-2016 04:22 AM
  1. Replies: 1
    Last Post: 01-16-2017, 09:16 PM
  2. Problems with gmail and music streaming after marshmallow update
    By acorn724 in forum Samsung Galaxy Tab S2
    Last Post: 08-10-2016, 06:20 PM
  3. August update changelog?
    By vVick3d in forum Nexus 5X
    Last Post: 08-09-2016, 04:48 PM
  4. Can't get Samsung Galaxy S5 to boot after Factory Reset
    Last Post: 08-08-2016, 09:42 PM
  5. Replies: 1
    Last Post: 08-08-2016, 08:50 PM
