1. banistersmind's Avatar
    I'm on Marshmallow now with my SGS7 and I'm noticing this annoying feature that limits my phone's charging to a slow, trickle charge whenever I'm plugged into my car's charging port.
    It's essentially useless as the phone drains at a normal rate and it doesn't charge.
    I want to disable this slow charging feature but I can't see an option.
    Any suggestions?
    08-27-2016 07:47 PM
  2. a_wiegmann's Avatar
    Is there an option for fast charging?
    08-27-2016 07:50 PM
  3. banistersmind's Avatar
    No.
    08-27-2016 07:50 PM
  4. a_wiegmann's Avatar
    If ur not using the fast charger or the correct charger cord it will do that u need a new charger cord
    08-27-2016 07:54 PM
  5. banistersmind's Avatar
    Must need to disable the fast charging setting then because my cord is the proprietary cord and it's brand new.
    08-27-2016 07:56 PM
  6. Ry's Avatar
    Any suggestions?
    What car charger are you using?
    08-27-2016 07:58 PM
  7. banistersmind's Avatar
    It's a plug that inserts into the cigarette lighter and I insert my cable into the plug. It's one of those dime a dozen Asian branded plugs.
    Interestingly, it's only started doing it since the 6.0.1 update.
    08-27-2016 08:00 PM
  8. a_wiegmann's Avatar
    Is the cable the one u got when u got the phone?
    08-27-2016 08:04 PM
  9. banistersmind's Avatar
    As I said previously, it's the proprietary cable, so yes.
    08-27-2016 08:09 PM
  10. a_wiegmann's Avatar
    Oh then Idk maybe someone else can help I'm out of options unless the cigarette lighter plug is bad
    08-27-2016 08:12 PM
  11. banistersmind's Avatar
    I'll try disabling the fast charge setting first and report back.
    08-27-2016 08:13 PM
  12. a_wiegmann's Avatar
    Ok hope that works for u
    banistersmind likes this.
    08-27-2016 08:20 PM
  13. banistersmind's Avatar
    Cheers.
    08-27-2016 08:25 PM
  14. JimSmith94's Avatar
    I don't know what the 6.0.1 update would have to do with it, but you definitely need a Quick Charge charger. Version 2.0 is for most phones, but you might as well get a 3.0 charger, since they're backwards compatible. I have a 2.0 charger for my Nexus 6 and it charges at roughly 1% a minute with Google Navigation running.
    badcat likes this.
    08-28-2016 12:05 AM
  15. Rukbat's Avatar
    "It's a plug that inserts into the cigarette lighter and I insert my cable into the plug" That's a stock charger and to Samsung that means USB charging (800mA maximum). You need a Samsung mobile charger adapter to charge at full capacity. (The pinout is different for full charge current in Samsungs.)
    08-28-2016 01:31 PM
  16. banistersmind's Avatar
    Disabling fast charging didn't make a difference.
    Will have to look for a proprietary car charger I guess.
    08-28-2016 04:54 PM
  17. patruns's Avatar
    In one of the more recent updates, "charging slowly" started appearing whether on a QI charger, ac charger or car charger. It appears to be a bug that has not been addressed. Google Android and charging slowly and you will see a lot of complaints.
    09-04-2016 01:42 PM
  1. Gps icon on and off on my phone with the GPS off.
    By Kel M in forum Samsung Galaxy S7 edge
    Last Post: 08-30-2016, 10:48 PM
  2. charging time for android phone
    Last Post: 08-27-2016, 07:29 PM
  3. Is there an alternate way to close apps on a Note 5?
    Last Post: 08-27-2016, 07:21 PM
  4. Replies: 0
    Last Post: 08-27-2016, 07:02 PM
