1. Svetlana Day's Avatar
    Can someone help me figure out the issue I've been experiencing with my Galaxy Note 5? I'm on AT&T, all updates installed, not rooted. The phone is new, but I've been getting a lot of battery drain. I have the beta version of Greenify installed and aggressive Doze turned on; I use ShutApp whenever too many apps are running in the background. My screen brightness is controlled by Lux, and usually set at very low %.
    I'm using GSAM to track the battery consumption, but I don't believe it's catching everything. The stock battery details is showing the screen as the main contributor to the battery drain, and the graph is steadily declining even when the screen is turned off. GSAM shows that the screen is consuming battery when it's turned off.
    How is that possible?
    I'll try to post some screenshots next
    09-07-2016 04:20 PM
  2. libor332's Avatar
    So what about AlwaysOn feature? Are you using it?
    edit: Sorry about that.
    09-07-2016 04:29 PM
  3. Svetlana Day's Avatar
    The battery graph showing the steady decline. The steep drop is when the screen was actually on, but was off for 99% of the time shown in the steady decline
    Battery drain: Screen consuming battery when the phone is sleeping-screenshot_20160907-130328.jpg
    Here is the Screen view
    Battery drain: Screen consuming battery when the phone is sleeping-screenshot_20160907-130332.jpg
    GSAM showing consumption from last unplugged (this morning when I left home) and fully charged (some time last night)
    Battery drain: Screen consuming battery when the phone is sleeping-screenshot_20160907-130345.jpg
    Battery drain: Screen consuming battery when the phone is sleeping-screenshot_20160907-130352.jpg
    And the screen details from GSAM showing that it's been on for 12 hours (or 5 days)
    Battery drain: Screen consuming battery when the phone is sleeping-screenshot_20160907-130405.jpg
    Battery drain: Screen consuming battery when the phone is sleeping-screenshot_20160907-130357.jpg
    Also GSAM screenshots from last night, showing the same behavior (5 days on for the screen and 91% battery consumption
    Battery drain: Screen consuming battery when the phone is sleeping-screenshot_20160906-234914.jpg
    Battery drain: Screen consuming battery when the phone is sleeping-screenshot_20160906-234905.jpg
    Thanks in advance for any tips!
    09-07-2016 04:37 PM
  4. Svetlana Day's Avatar
    No, not using AlwaysOn. It would make sense... and I wouldn't be asking. Actually, it's not even available on the Note 5
    09-07-2016 04:37 PM
  5. kroalnumber2's Avatar
    If it's any help, for me, moderate-heavy usage, Samsung S6 edge, I get roughly 3 and a half hours screen-on time out of a full 100% battery use. And with ONLY the Doze app, I lose around 2% overnight..
    Did you post them screenshot after a full 100% use of the battery?
    Also I apologise if you have and I've misread your graphs haha
    09-15-2016 06:47 AM
  1. Price drop on the X to $449... Thoughts
    By Dconn1975 in forum Sony Xperia X & X Compact
    Last Post: 01-07-2017, 08:25 PM
  2. Split Screen?
    By neil123456 in forum OnePlus 3 & 3T
    Last Post: 09-08-2016, 01:46 PM
  3. How to delete the picture?
    Last Post: 09-07-2016, 03:46 PM
  4. Phone factory reset and now images out of order in gallery
    Last Post: 09-07-2016, 03:42 PM
  5. What should i do when my phone wont restart properly?
    Last Post: 09-07-2016, 03:16 PM
