1. Mamaluka's Avatar
    I have a Verizon note 4. I just ported my number to t-mobile and want to get rid of the stock Verizon marshmallow and use a stock t-mobile marshmallow version. My question
    Can I do this?
    Where can I download a stock version of the latest t-mobile marshmallow for the note 4?
    Thanks!
    12-29-2016 01:38 PM
  2. hallux's Avatar
    There are differences in the hardware, the T-Mobile firmware won't work correctly on the Verizon device.
    TwitchyPuppy and Laura Knotek like this.
    12-29-2016 01:48 PM
  3. Mamaluka's Avatar
    Thanks hallux. I went to a local phone repair shop and my guru Droid guy told me the same thing. Don't do it. He also highly recommended not rooting the phone and throwing any roms on it. He basically told me to do what I had already done... Put all Verizon related apps in a junk folder, go to play store and download any t-mobile apps I wanted to use. Which I did.
    12-29-2016 03:11 PM
  1. Replies: 1
    Last Post: 12-30-2016, 02:35 PM
  2. Replies: 1
    Last Post: 12-30-2016, 01:42 PM
  3. What's going on to my s7 edge?
    Last Post: 12-29-2016, 01:31 PM
  4. Replies: 0
    Last Post: 12-29-2016, 12:54 PM
  5. connect android tv box to pc with usb to usb cable
    Last Post: 12-29-2016, 12:15 PM
