F FinnishIron New member Jan 13, 2017 2 0 0 Visit site Jan 13, 2017 #1 I bought H96 Pro Plus Android TV (Android 6). When I am about to install I got the error message: "Unfortunately System UI has stopped" What should I do??? Thanks, David
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,582 4,725 113 Visit site Jan 14, 2017 #2 Welcome to Android Central! When you're about to install what -- an app? Or are you talking about the initial setup of the box?
F FinnishIron New member Jan 13, 2017 2 0 0 Visit site Jan 14, 2017 #3 To set up I meant connect the first time. I found the fault, I did connect SD micro card before I started it first time. When I took the SD micro card away all functions normal.
A allisondeutsch New member Jan 22, 2017 2 0 0 Visit site Jan 24, 2017 #4 I had same problem. Fixed it by un installing Google app's update.
