1. beau02's Avatar
    Hi,
    I was wondering what to do about my microsd only formatting as external on my phone not internal/adaptable?? Thanks
    05-13-2017 06:43 AM
  2. ManiacJoe's Avatar
    Which phone?
    Which version of android?
    Which carrier?
    Not all versions of android support adaptable storage.
    Not all phones support adaptable storage.
    Given the problems that can occur, my recommendation is to leave the card formatted as external storage, put your media files on it, and leave the apps on the internal storage.
    Check the settings of your apps that use lots of storage space. Some of them will let you put their data on the SD card.
    (Camera, GPS, maps, etc.)
    05-13-2017 04:57 PM
  1. Common Galaxy S8 problems and how to fix them
    By LineKill in forum Samsung Galaxy S8 & S8+ Member Guides
    Last Post: 05-16-2017, 10:06 AM
  2. [Music files problem]
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 05-12-2017, 02:23 PM
  3. [Music files problem]
  4. Problem setting up a Microsoft Exchange email on LG G4
    Last Post: 05-12-2017, 08:41 AM
  5. wifi problem
    Last Post: 05-12-2017, 07:11 AM
