1. eldorado82's Avatar
    hello everybody
    just bought a new phone- Lenovo phab 2 plus PB2-670M with android 6.0
    i have those quicksettings- that you get when you swipe to times down on the main screen where are the "WLAN" "cast" tiles and so on. the problem is that i cannot edit the number of the tiles i need to be there, i mean i don't need all of them!
    as i found in the web, some guides tell just hold the cog untill it begins to spin, and then you'll have option added in menu in "system" or that a wrench appear next to it and then you can remove the tiles you don't need. in both cases nothing works. the cog spins but nothing happens. in the other case no wrench appears.
    i can tap icon of pencil and 7 dots and its opens a window but i can remove only two tiles!
    my inner OCD goes crazy because i need maximum 3-4 tiles in there
    is there anything that can be done or its only routing and so on?...
    some info about the phone
    kernel version 3.18.19
    build number PB2-670Ms000044_161029_ROW
    software version PB2-670M_160719
    hardware version LenovoPad PB2-670M
    ill be gratefil for each help that you can provide
    thanks in advance
    David
    05-25-2017 04:10 PM
  2. SpookDroid's Avatar
    Unfortunately the guides you're reading probably apply to stock Android or devices where the UI Tuner is active. Some manufacturers, and I'm assuming this is the case, disable that. Furthermore, they might not allow customization of the notification shade or the quicksetting buttons.
    eldorado82 likes this.
    05-25-2017 04:22 PM
  3. eldorado82's Avatar
    so you say its a lost case? nothing can be done?
    or rooting the phone and getting some app from the Play market like "SystemUI tuner" it might help?
    05-25-2017 04:30 PM
  4. Javier P's Avatar
    Welcome to the forums. I agree with SpookDroid, as far as I know Lenovo enabled the System UI tuner only on Moto devices. Sorry. It seems Lenovo included a similar feature in settings - notification centre, but I don't know if the options you are looking for can be found there.
    05-25-2017 04:45 PM
  5. eldorado82's Avatar
    hmmm
    so its nothing to do, yes?..
    05-25-2017 04:47 PM
  6. Javier P's Avatar
    hmmm
    Not sure. I can search about this a bit later, but root and some module seem the way to go. I guess it's a radical path for such a small thing, though. I'll let you know if I find something else.
    SpookDroid likes this.
    05-25-2017 04:53 PM
  7. Javier P's Avatar
    What about safe mode? Have you tried it?
    https://forums.lenovo.com/t5/P2-P2a4...t/td-p/3628857
    05-25-2017 05:26 PM
  1. Replies: 3
    Last Post: 05-25-2017, 10:44 PM
  2. Is anyone happy with their kyocera hydro?
    Last Post: 05-25-2017, 02:51 PM
  3. I Phone 6P e-mail sync problems with computer
    Last Post: 05-25-2017, 10:15 AM
  4. Using BB Hub on Note 5 with Nougat and read emails keep opening
    By texn884 in forum General Help and How To
    Last Post: 05-25-2017, 09:08 AM
