1. sagarkls's Avatar
    I have a redmi note 3 and via OTA update i have o
    Got volte in my mobile.. but now when volte is on and when my mobile is connected with wifi any download from play store and in some apps it needs time to take the speed after spped is very good but it needs vey much time in some apps and in play store.But in speed test i am getting 4 mbps speed.But when i off the volte with the same wifi my mobile play store and other apps works fine. My computer with wifi it works fine to. Why this problem arrise when volte is on.nd how to fix this.. i found that with volte on i need to use dns changer thn it works fine with wifi and volte is on..how to solve this without using dns changer
    12-22-2017 12:37 PM
  2. Rukbat's Avatar
    You don't. Use 8.8.8.8 and 8.8.4.4 as your DNS addresses. (They're usually better than the ones your ISP provides anyway. Those are Google's DNS servers.)
    12-22-2017 01:39 PM
  3. sagarkls's Avatar
    I used every thing google dns open dns but nothing works i even reseted my phone and router but same issue..... i have changed dns to google dns in router setting but nothing works.
    12-22-2017 03:24 PM
  4. sagarkls's Avatar
    Why the problem with volte
    12-22-2017 03:24 PM
  1. Galaxy Tab E Lite Android Update
    Last Post: 12-08-2018, 12:02 AM
  2. Why won't my emails deleteWhen I go to delete emails it says e
    Last Post: 12-23-2017, 12:08 AM
  3. Why was the app deletion changed? Horrible update!
    Last Post: 12-22-2017, 03:00 PM
  4. how to I set apps to only use certain wifi connections and not others?
    By Wraiththe in forum General Help and How To
    Last Post: 12-22-2017, 01:55 PM
  5. Replies: 1
    Last Post: 12-22-2017, 01:41 PM
