1. Evilde1sel's Avatar
    I bought a seicane s0480 with the andriod o.s. 6.0.1
    Now i have an issue with the screen.
    I can press the middle of the screen and it selects whats there just fine..
    Now my menu is top left. In order to select it i have to touch the bottom for back, home and opened apps.
    This goes for everything... keyboard.. forget about it touching the letters does nothing. But if you go above the keyboard "where there is nothing" your guessing what letters you have to push.
    I was told by a guy on a mazda forum to factory reset it should fix it or the touchscreen connection maybe loose.
    Manufacture wont respond. I do have usb spots so i could try getting a mouse and keyboard but at that i mise of well take it out..
    Will an update or factory reset fix this issue?
    12-23-2017 07:08 PM
  1. Translate from screen (google app)
    Last Post: 12-24-2017, 01:06 AM
  2. I keep getting the message "Close apps causing performance issues?"
    Last Post: 12-24-2017, 01:01 AM
  3. I am not getting a home screen to be able to set up my mxq pro
    Last Post: 12-23-2017, 05:57 PM
  4. Why is my call in screen black on my google pixel 2?
    Last Post: 12-23-2017, 02:18 PM
  5. Touch Screen Hinky After I Replaced Charging Port
    Last Post: 12-23-2017, 01:54 PM
