1. Zendroid1's Avatar
    I'm sure this is a really easy one but for some reason I can't seem to find the option to turn on the notification LED on my 5X? I have been looking everywhere! I'm probably just losing my mind.
    03-18-2016 03:15 PM
  2. B. Diddy's Avatar
    Just to be sure--you're talking about the Nexus 5X, and you are on the N developer preview, right? I want to make sure this wasn't posted in the wrong forum.
    03-18-2016 10:59 PM
  3. Zendroid1's Avatar
    Correct.
    03-18-2016 11:04 PM
  4. Zendroid1's Avatar
    Found it. Settings notifications then the gear. I could have sworn it was someplace else in marshmallow.
    B. Diddy likes this.
    03-19-2016 02:02 PM
  5. qfnol31's Avatar
    I believe there is a bug with the LED on N as well. I think I saw it reported in the bug report list, so if it doesn't work as you might expect (charging), that's why.
    03-20-2016 09:49 PM
  1. How to disable sync notification pop up
    By dinoo82 in forum Samsung Galaxy S7 edge
    Last Post: 10-18-2016, 08:07 PM
  2. How do I get rid of the Xinyinhe adware?
    Last Post: 07-09-2016, 01:30 PM
  3. how do i change my connection mode to media device on samsung s6?
    By Kirsty Macleod in forum Samsung Galaxy S6
    Last Post: 03-18-2016, 04:23 PM
  4. How to reset fingerprintpassword
    Last Post: 03-18-2016, 03:14 PM
