Nexus 5X (16GB)
Build NPD56N
ATT
At home, on WiFi
Anyone notice extremely high battery drain after casting to a Chromecast device? I'm not sure if there is a connection and I forgot to generate a bug report. But after weeks of completely normal battery drain, I cast my screen to my Chromecast device (first time on Android N) and then forgot to stop casting. Later, I noticed higher than normal drain, realized I was still casting and terminated the cast. According to the battery graph, looked like the drain stopped but then resumed and discharged maybe 50% overnight (100X the normal standby drain). Battery stats did not add up to the total drain and did not show any unusual usage. I rebooted and am charging now. I assume the reboot will fix it, but something is amiss.
Paul
Build NPD56N
ATT
At home, on WiFi
Paul
