1. Don_Henry's Avatar
    Is anyone else having the problem of Bluetooth disconnecting while on a call? I own two Plantronics Pro HD earpieces - both worked fine on MM - but on N DP 3 and 4, the earpieces will disconnect, and then reconnect 1-2 seconds later. However, after reconnecting to my N5X, they do not reconnect to the call I am on - I must manually toggle between speaker and earpiece a couple of times to get the earpiece connected back to the call.
    I have reported this to Google - just wondering if anyone else is having this problem.
    NEXUS 5X on AT&T on N DP4
    07-06-2016 12:09 AM
  2. JimSmith94's Avatar
    I had this problem on my Nexus 6 on stock rooted Marshmallow 6.0.1 so much with my Plantronics Voyager Legend that I bought the new Voyager 5200. It was pretty good for a month or so, but lately it has been disconnecting and reconnecting during phone calls, and sometimes when it's just in my ear and I'm not on a call. I have to manually switch to the earpiece or speakerphone until my headset reconnects on its own.
    I have tried 5.32, 5.34, and 5.36 radios but they don't make any difference with this. Hopefully someone can point us to a solution.
    Don_Henry likes this.
    07-07-2016 11:30 PM
  3. doggy2965's Avatar
    My Bluetooth devices seem to work good for awhile. Then they start having a problem. I usually just totally reconnect them then there fine for awhile
    07-08-2016 06:51 AM
  4. Don_Henry's Avatar
    Thanks for the replies - this sounds like a BT driver problem - hopefully Google is paying attention to reports from users (I have reported this more than once since being on N.
    I did not have any of these problems on MM.
    07-08-2016 09:24 AM
  5. JimSmith94's Avatar
    Mine actually started when I installed the first N beta through MultiRom. I thought it might have been from having the headset paired to the same phone twice (M and N), but even after a complete wipe and reload of just M, it still continues to disconnect. I have forgotten and reconnected the headset many times, but it always comes back.
    07-08-2016 02:09 PM
  6. anon(9072051)'s Avatar
    Weird. I've been having significantly better luck with BT on DP4 than on MM or DPs 1-3. Course I don't own any Plantronics devices. Any chance it could be something like an HD Voice issue? Say the person on the other end not using a compatible device??
    07-08-2016 02:51 PM
  7. Don_Henry's Avatar
    Because I have an unlocked device, I don't have HD Voice - and some of the people I speak on the phone with don't use any earpiece.
    07-08-2016 05:22 PM
  8. eric002's Avatar
    Yes, with developer preview 3 and 4, the SAME issue failed in my car. It's a 2014 civic si And the BT would disconnect soo much and creaTe soo much frustration, I just found up turning it off. So far, it seems that developer preview 5 fixed that issue finally! It's usable again.
    07-25-2016 11:01 AM
  9. Don_Henry's Avatar
    I also have found the problem seems to have been corrected in DP5 - since the update, I have not had any disconnection issues.
    NEXUS 5X ON AT&T ON 7.0 DP5 - Posted via the Android Central App
    JimSmith94 likes this.
    07-30-2016 10:07 AM
  10. luc lucky's Avatar
    Yep, i have the same issue on note 3, s6 and lg g4, with two different earpiece Plantronics voyager pro. This occurs since one year ...no idea to solve this annoying issue
    09-21-2016 12:44 AM
  11. JimSmith94's Avatar
    I thought this was related to having an Android Wear watch connected, so I wrote a Texter profile to keep the watch's Bluetooth disconnected while on a call. I thought it was finally fixed on the official Nougat, and even disabled my Texter profile, but it disconnected on me again today.
    10-10-2016 03:48 PM
  12. Don_Henry's Avatar
    Just today - I had the "disconnect/instantly reconnect" thing happen - first time since DP5 (and I am on official since it came out} - hopefully just a freak occurrence.
    10-10-2016 09:59 PM
  13. JimSmith94's Avatar
    Mine disconnected/reconnected again yesterday. It was only once and it reconnected before I could reach for the speaker button on my phone, so it's better, but still not perfect.
    10-13-2016 09:49 AM
  14. JimSmith94's Avatar
    The multiple disconnects are increasing again on my Nexus 6 running stock rooted Nougat. I've finally had enough with this phone and have a mint 6P on the way.
    10-15-2016 08:55 AM
  1. intermittent charging problem
    By Janeyb999 in forum Samsung Galaxy S6 edge
    Last Post: 07-10-2016, 07:15 AM
  2. How can I stop hiccups in bluetooth audio playback?
    By halfbeing in forum Audio & Video
    Last Post: 07-06-2016, 06:17 AM
  3. What is this heart icon with the letter S in it?
    Last Post: 07-05-2016, 11:29 PM
  4. Replies: 0
    Last Post: 07-05-2016, 09:54 PM
  5. Boot loop with blue screen
    By raidencmc in forum LG G3
    Last Post: 07-05-2016, 08:53 PM
