1. Clifton Richie's Avatar
    My 6p's phone signal is poor. I get a lot of dropped calls on Verizon; with my work phone that is a Galaxy s6, none. Does anyone have any knowledge on whether 7.0 may help with this or is it a hardware issue? I'm asking bc I pre ordered a Note 7 and the scratch issue is a red flag for me. I'd keep my 6p if I could have a more reliable call experience. I combed through the net, looking for answers but to no avail.
    08-19-2016 06:08 AM
  2. VidJunky's Avatar
    There are some reception issues that can be improved with regard to software updates, however for the most part it really comes down to hardware.
    08-19-2016 12:45 PM
  3. mdcool's Avatar
    This sounds like a hardware issue. If updating to Nougat doesn't help you might need to change phones.
    08-19-2016 10:43 PM
  4. Clifton Richie's Avatar
    I already changed to the Note 7. I miss my Nexus but damn this phone is nice!
    08-20-2016 12:26 PM
  5. theduder's Avatar
    There are new radio firmwares from time to time. Not all carriers adopt them - Google currently has builds with different letters denoting the upgraded radios. For my Nexus 6 for example, there is an MMB build (older radio firmware) and MOB (newer). AT&T pushes the old one but you can install the newer one yourself. I'm sure Verizon tests the firmwares rigorously and probably is similarly slow to adopt anything that changes the behavior of the handset's interaction with the towers.
    08-21-2016 03:24 PM
  6. Kamera Rusak's Avatar
    so your signal is back to normal? its software issue then
    08-22-2016 09:45 AM
  7. doggy2965's Avatar
    My 6p signal isn't great on Verizon either. If nougat doesn't improve in then I'm selling it
    08-22-2016 12:59 PM
  8. Clifton Richie's Avatar
    My signal is much better with the Note 7. If my 6p gets better with 7.0, I'm giving this thing back.
    08-22-2016 01:32 PM
  9. racedog's Avatar
    Could you post the actual -dbm readings for each phone please.
    08-22-2016 01:49 PM
  1. Samsung J5 with 8GB of memory
    By andersh in forum Samsung Galaxy J Series
    Last Post: 10-18-2016, 10:14 PM
  2. Battery drain after switching to new phone
    By yarnsrj in forum Verizon Samsung Galaxy Note 3
    Last Post: 08-27-2016, 08:01 AM
  3. why my j7 automatically resticked many apps bacground data
    Last Post: 08-26-2016, 05:02 AM
  4. Went from 6p to Note 7. Arrrrgh! Help I have Questions!!
    By CincyGuy in forum Samsung Galaxy Note 7
    Last Post: 08-19-2016, 10:52 AM
  5. Replies: 0
    Last Post: 08-19-2016, 05:40 AM
