1. wilmah's Avatar
    So I updated my 5x through the beta registration. Loving it so far. I can't seem to turn on the UI Tuner with the gear icon on quick settings though.
    Anyone else notice this? I've already enabled developer settings- not sure if that has anything to do with it.
    08-25-2016 09:35 AM
  2. B. Diddy's Avatar
    Have you changed the Animation settings in the Developer Options? If so, change them back to normal and try again.
    08-25-2016 12:25 PM
  3. wilmah's Avatar
    Ahh- that did it. I had all my animations shut off in the developer settings. Thanks a lot!
    B. Diddy likes this.
    08-25-2016 05:40 PM
  4. B. Diddy's Avatar
    Great! I learned that little tidbit from Javier P, one of our other Ambassadors.
    08-26-2016 02:35 AM
  5. TechReviews1's Avatar
    Try to switch off your Developer Options then enable the System UI Tuner. Then re-enable the Developer Options if you wish. Hope this helps!
    08-27-2016 09:33 PM
  1. Best Practices: Clear Apps Cache, Clear System Cache
    By Shamshi-Adad in forum Samsung Galaxy Note 7
    Last Post: 08-29-2016, 12:19 PM
  2. Has the lasts update for Note 4 over powered the operating system?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 08-28-2016, 10:22 PM
  3. Replies: 1
    Last Post: 08-25-2016, 11:31 AM
  4. Replies: 0
    Last Post: 08-24-2016, 02:42 PM
