12-15-2016 03:56 PM
45 12
tools
  1. tgp's Avatar
    I bought my 6P used about 6 months ago, and I never have been all that impressed with its battery life. It was OK on Marshmallow, but I thought it could be better. I got Nougat via official OTA earlier this week. Battery life has been somewhat worse since then.
    I have not ever yet done a factory reset other than the initial reset before setting it up for the first time. There have been many monthly updates and one OS version update since then. I'm about to do that and see if it helps.
    09-23-2016 01:24 PM
  2. anon(9072051)'s Avatar
    How does one turn off 5GHz WiFi? I cannot find in any WiFi settings how to do that.
    Do you have WiFi Assistant enabled? Or is it built into the final version of Nougat? Could be the assistant is in control of selecting the best frequency band per network.
    The option to select 2.5 or 5 used to be under Settings > WiFi > Advanced > Frequency band, I think. But it's no longer available on my N6 either (which is running DP5 with WiFi Asst enabled).
    tonyr6 likes this.
    09-23-2016 02:25 PM
  3. Don_Henry's Avatar
    I don't have WiFi Asst - and not listed on Play as an available app
    09-23-2016 02:52 PM
  4. anon(9072051)'s Avatar
    It's not an app; it was rolled out as part of an update to Connectivity Services. The toggle lives under Settings > Google > Networking. But if you don't got it, you don't got it.
    09-23-2016 03:47 PM
  5. Don_Henry's Avatar
    Thanks - and I, like you - don't got it
    09-23-2016 03:52 PM
  6. KWKSLVR's Avatar
    Thanks for any help! (Note that I am on a 5X running 7.0)
    I think he means turning it off on his WiFi network, not from the phone.
    09-24-2016 01:21 AM
  7. Don_Henry's Avatar
    Thanks - but I did mean how to turn it off on the phone.
    09-24-2016 09:55 AM
  8. NazmiVDW's Avatar
    yeah i agree. love the extended Doze feature - sometimes if I ignore my phone in my bag or pocket while on the move, the battery level didn't budge much (unlike with Marshmallow) Put Data Saver on top of this and it may go on for even longer.
    09-27-2016 03:58 AM
  9. Spectech7's Avatar
    What are the main additions to the Android Nougat? What have they removed from Marshmellow and what has improved?
    09-27-2016 04:53 PM
  10. Alex Dobie's Avatar
    Here's what's new: Android 7.0 Nougat: Everything you need to know | Android Central
    09-30-2016 03:59 AM
  11. maizhaoiv's Avatar
    So let's wait the Android 7.1 update for battery drain fix.
    09-30-2016 05:19 AM
  12. scoutzdad's Avatar
    Sorry just saw this.... I didn't physically turn it off in the phone, I just "forgot" the 5GHz network my wireless router broadcasts so my phone I only connects to my 2.4 GHz network. My router is setup to broadcast both a 5GHz and 2.4GHz band. Seemed to do the trick for me.
    10-03-2016 11:31 PM
  13. maj429's Avatar
    I FOUND OUT HOW TO STOP NEXUS 6P NOUGAT BATTERY DRAIN FOR ME. Go into developer options, disable automatic system updates, and disable always allow wifi roam scans. Restart. Fixed.
    10-10-2016 03:58 PM
  14. Bryan Coe's Avatar
    I just received the 7.1 update a couple of days ago (beta program) and so far it hasn't helped with the battery drain. It may have even made it worse. The first Nougat update actually made my battery last longer than before. I was getting almost 2 days out of it. Now I get maybe 8 hours. When I look at what's using the most power it is by far "Android System" and second "Android OS." I've never seen that happen before. It's getting very frustrating.
    10-21-2016 08:59 AM
  15. zambi82's Avatar
    Same on my 5X
    10-21-2016 01:22 PM
  16. lutzer21's Avatar
    Does this actually work?
    11-21-2016 05:53 PM
  17. maj429's Avatar
    It worked for me, that's why I said "for me" you should try it and find out. I've since upgraded to an AXON 7 and enjoy epic battery life.
    11-22-2016 04:33 PM
  18. anthonium's Avatar
    So for most current 6p owners, would you say battery still continues to be an issue? Depending on this is whether I'll fork out the cash to buy a 64gb 6p this black friday. I currently have a 4 yr old phone with a battery that barely lasts half a day before I need to charge and that's with very minimal use...
    11-24-2016 09:19 PM
  19. SRFast's Avatar
    I am running the latest beta version of Nougat on my 6P and have no battery issues. Battery life depends on what you do on your phone.
    11-25-2016 05:47 PM
  20. puch96's Avatar
    For me battery is about the same on 7.1.1 vs. 7.0. However, from time to time, my battery will reach near 20% then my phone will shut down without warning. Hopefully Google fixes this annoying issue.
    12-15-2016 03:56 PM
45 12
  1. Replies: 4
    Last Post: 09-13-2016, 05:07 PM
  2. email problem on s4
    Last Post: 09-08-2016, 09:51 PM
  3. Gear Fit2 Always On Watch Face Keeps Turning Off
    By LateOnTheBrakes in forum Samsung Gear Fit 1 & 2
    Last Post: 09-08-2016, 08:58 PM
  4. Always On Watch Brightness
    Last Post: 09-08-2016, 08:54 PM
  5. How to sync trash folder on juno email.
    Last Post: 09-08-2016, 08:44 PM
