1. Abhitot's Avatar
    After installing Android 7, battery of my 6p drains like a hail. Within 6 hours I have to charge my mobile. What to do?
    09-30-2016 12:59 AM
  2. ratsttam's Avatar
    If you just did an upgrade from 6 to 7, You might find that a factory reset will clear up all the errors. Sometimes things don't install or update correctly causing issues with stuck processes and battery drain / slowness.
    Hypnotoadd likes this.
    09-30-2016 03:23 AM
  3. cactuspete23's Avatar
    Maybe I am missing something in that link? But only see reference to "night mode" and wonder if that is Abhitot's issue? Agree good to try rattsam's advice.
    09-30-2016 06:50 AM
  4. brutos08's Avatar
    It's happening to quiet a few people myself included also phone gets very warm when using it
    09-30-2016 11:41 AM
  5. Abhitot's Avatar
    Thanks a lot. Tried system UI Tuner settings. But in that only status bar, do not disturb and other icons are appearing. No colour appearance icon found to activate night mode. I did factory resetting now. Let us see whether battery life increases or not.
    09-30-2016 09:29 PM
  6. waoul1988's Avatar
    factory reset and maybe dose is studying ur habits it happens the first week, if u check ur battery u'll see that the android system is drainin more than the screen
    10-01-2016 05:26 AM
  7. cactuspete23's Avatar
    Interested to hear what you find
    10-01-2016 06:44 AM
  8. Abhitot's Avatar
    After factory reset, prima facie battery life has increased somewhat. Will give you exact feedback after couple of days. Thanks a lot
    10-01-2016 06:52 AM
  9. Gimmuniverse's Avatar
    Try wiping battery cache and factory reset. It will mostly work if Android 7 came to your device officially
    10-01-2016 10:39 AM
  10. tonyr6's Avatar
    Wiping cache does nothing for me a placebo effect like Windows sfc /scannow. Factory reset almost always fixes my issues too like Windows System Restore but unlike Windows Google has a horrible restore system.
    10-03-2016 03:08 PM
  11. Abhitot's Avatar
    I think batter draining problem of my nexus 6p has been solved after downloading October 5th patch. Thanks a lot everyone.
    10-08-2016 09:09 AM
  12. anon(55900)'s Avatar
    Yeah, that's normal, probably last no more than 48 hours, when I first installed NBeta my Nexus6 did it and then later I left Beta, reload Marshmallow and the after ota release for N6, went back into Beta for release and it did it again.
    10-09-2016 04:07 PM
  1. HTC 10 high battery drain when screen off?
    By AC Question in forum HTC 10
    Last Post: 11-20-2016, 08:05 PM
  2. Alarm clock issue with Note 7
    By spasell in forum Samsung Galaxy Note 7
    Last Post: 10-03-2016, 05:55 AM
  3. Replies: 3
    Last Post: 09-30-2016, 04:10 AM
  4. Galaxy S7 Edge messaging issues!
    Last Post: 09-30-2016, 12:14 AM
  5. Replies: 6
    Last Post: 09-29-2016, 10:10 PM
