1. PsychDoc's Avatar
    Though I've only had it for a day, it seems that nougat has improved battery life considerably. I have performance set to "optimized" as recommended and I see no decrease in performance so if that's what's improving battery life, I'm fine with that.
    What's been your experience with battery life since the move to nougat?
    03-26-2017 07:19 AM
  2. jasonandrews25788's Avatar
    it depends on the phone itself as my S7 had many battery problems I managed to fix but the PIXEL hadn't any at all.
    03-26-2017 11:49 AM
  3. jimd1050's Avatar
    I'm running a Galaxy S7 Active with the 4000 mAh battery, using "Mid" Level Power Saving Mode and it's been off the charger for 1 day, 14 hours, 7 mins, 30 seconds and says it's at 61% (expects to last another 37 hours, 49 minutes)! When I switched to "Mid" Level, I really saw NO Performance Hit at all, either... not that I noticed any way. The display blanks sooner, I think it shuts off Wireless if I haven't used it in a while... stuff like that. Doesn't mess with the "processor" or any other performance related stuff unless you go to "Max" Mode!
    *Just checked - Screen On Time was only 9 Hours 48 minutes for that period though!
    03-26-2017 01:25 PM
  1. Replies: 2
    Last Post: 05-28-2017, 10:07 PM
  2. Holding power button for 1 or 2 seconds restarts UI. Need help.
    By hassanification in forum Moto G (2014)
    Last Post: 04-07-2017, 07:48 AM
  3. Budget phone under 300 with nougat and good spec
    By scalabrine playoff 3pt 46 curry playoff 3pt 40 in forum Buyers Guides
    Last Post: 03-29-2017, 06:42 PM
  4. Why is my battery fluctuating?
    By Taha Humayun in forum Ask a Question
    Last Post: 03-26-2017, 12:46 PM
  5. Replies: 1
    Last Post: 03-26-2017, 03:56 AM
