1. XxTiffany86xX's Avatar
    I have recently installed the update for the LGG5 nougat 7.0. My battery drains fast, battery over heats, and when I plug my phone in to charge it will say changing and then it will say discharging. I can plug it into a computer and it charges slowly but this is such an inconvenience for me. Anyone else having this problem or know how to fix it? Please help...
    03-26-2017 11:19 PM
  2. J Dubbs's Avatar
    With those pretty major issues you're most likely going to have to do a factory reset.
    Operating system upgrades are major changes, and factory resets seem to be the required fix for Android problems that come with the upgrade.
    03-27-2017 07:22 AM
  1. I have a pop up that says MIP:67 on my lg k3
    By Footballfanatic2 in forum General Help and How To
    Last Post: 03-27-2017, 06:06 PM
  2. Is there one good Messaging app from Android to put on Pixel?
    Last Post: 03-27-2017, 12:28 AM
  3. Replies: 1
    Last Post: 03-26-2017, 11:33 PM
  4. Bluetooth on Chromecast
    By K_Daddy in forum Ask a Question
    Last Post: 03-26-2017, 11:06 PM
