1. markm75's Avatar
    I had previously posted a thread regarding battery drain on my s7 edge
    Since then i solved it by wiping it clean, starting from scratch and slowly adding apps/services.
    I've been getting awesome turned off gsam of 0.6% per hour drain at night and maybe 1% to 1.5 at worst during the day..
    Today i activated and opted into the google app options..
    Now at work i'm seeing wifi never sleeping or rarely sleeping (coincidence?).. and an overall drain of 2-5% per hour during the day.
    Could the wifi etc be caused by the google app somehow?
    Anyone ran into this
    Thanks in advance
    05-24-2017 03:11 PM
  2. J Dubbs's Avatar
    That seems to be a common problem with Google services on nougat.....and appears to be a big part of the nougat battery drain issues :-(
    05-25-2017 05:46 AM
  3. badcat's Avatar
    Check to see if all the services are syncing correctly. On one of my phones Contacts wouldn't sync properly and was stuck in a loop sucking up my battery. Turning off sync for Contacts fixed it and for whatever reason I could still sync manually.
    05-25-2017 10:20 AM
  4. markm75's Avatar
    Ill check for that, but not sure where you would see this indicated as ongoing..
    However.. i'm nearly certain my battery drain started as soon as i opened the google app.. opted in to all the "cool features".. it doesnt always show up in gsam as google or google services using wake locks, i think it gets mixed into the android system and the kernel for wake lock usage instead.
    If i disable google app, google framework services.. things settle down.
    05-25-2017 10:48 AM
  5. badcat's Avatar
    If I remember correctly my battery usage showed Google Services eating the battery. What I did to check it was I went into Accounts, selected Google, and it showed a list of what is being synced by Google. The contacts section showed a circular arrow I believe and some text that indicated it wasn't syncing. I turned off the contact sync and the problem went away.
    I'm not saying this is your issue. It's just an easy thing to check. Maybe the app is causing it. I don't use a lot of those features myself.
    05-25-2017 04:01 PM
  6. Schottky's Avatar
    I haven't updated to Nougat but I had a problem with the Google App, if I remember rightly. This was running Marshmallow. I cured the battery drain problem by turning 'Your feed' off in Settings.
    badcat likes this.
    05-25-2017 04:26 PM
  1. Anyone else having issues with Nougat on a Galaxy Note 5?
    By bnewall1 in forum Android 7.0 Nougat
    Last Post: 06-07-2017, 05:44 PM
  2. More options button not working in email to bring up print
    Last Post: 05-24-2017, 10:02 PM
  3. Replies: 1
    Last Post: 05-24-2017, 06:48 PM
  4. No sound when playing videos on my Android TV
    By YaniEi in forum Audio & Video
    Last Post: 05-24-2017, 03:12 PM
  5. Replies: 0
    Last Post: 05-24-2017, 01:57 PM
