1. Ian Freeman's Avatar
    Since my s6 updated in the last two weeks it's started coming up with battery notifications, not the usual ones u get at 15%and 5% but ones at random percentage, 22% and 14% (but not always these)
    I've got a screen shot which I'll post, I just want to get rid of them if I can
    06-19-2017 04:09 PM
  2. matthewkuhl's Avatar
    The real question is "Why are you killing your battery?"
    Best not to drain it that deeply, mate.
    J Dubbs likes this.
    06-19-2017 04:50 PM
  3. Ian Freeman's Avatar
    So start charging it at what percentage?
    06-19-2017 04:56 PM
  4. Trigati's Avatar
    Personally, i don't like going below 30% but 20% is the lowest I take my battery. I also use Accubattery from the Play store and don't charge the battery above 80% as much as possible to keep my battery as healthy as I can.
    06-21-2017 08:28 AM
  5. matthewkuhl's Avatar
    50% Is kind to the battery. i don't generally go below 40% without a reason for it.
    Not charging above 80% is silly.
    J Dubbs likes this.
    06-26-2017 06:45 AM
  6. Trigati's Avatar
    Google "why you shouldn't charge your phone to 100". More than enough articles explain info things there.
    I like to follow the 40-80 rule as much as possible.
    06-27-2017 07:46 AM
  7. matthewkuhl's Avatar
    Sure Captain.
    06-28-2017 08:49 AM
  1. Replies: 32
    Last Post: 06-21-2017, 08:36 AM
  2. Running VPN / battery drain
    By christophermccarthy in forum Google Pixel & Pixel XL
    Last Post: 06-20-2017, 07:23 PM
  3. Replies: 2
    Last Post: 06-19-2017, 04:47 PM
  4. LG G6 screen stays lit after notification.
    Last Post: 06-19-2017, 03:09 PM
  5. Why is my phone switched off when battery reduces
    Last Post: 06-19-2017, 05:36 AM
