1. V MP's Avatar
    I have noticed on my new Huawei P10 - Version Nougat 7.0 that whenever I put it on Batter Saver mode (not the Ultra saver mode) background apps and functions are being disabled, especially the email sync.
    Whenever I open my email client (in this case a trial BlueMail and Typeapp) I am being asked to enable Sync; I click to enable but nothing happens. It keeps asking me to enable it and the whole syncing facility is staying all greyed out, i.e enabling is not working.
    Then I go to settings/accounts and manually sync the accounts, it does sync but automatic sync is still greyed out on the top right corner.....
    Is this a characteristic of the Android 7.0? If yes, what is the point of giving us the option to save battery?
    Is there a solution to get around this by any chance?
    Thank you.
    06-25-2017 02:06 PM
  2. PJRed2008's Avatar
    The solution is to manage each app's battery usage manually or disable the battery saver. Can't have both, and yes, that is characteristic of N.
    06-25-2017 02:18 PM
  1. Nougat update
    By Mistizoom in forum Axon 7 & Axon 7 mini
    Last Post: 07-05-2017, 12:36 PM
  2. Battery Drain when idle vs LG G6
    By neil74 in forum Samsung Galaxy S8 & S8+
    Last Post: 06-27-2017, 03:18 PM
  3. Is Android Debug Bridge safe?
    Last Post: 06-25-2017, 07:29 PM
  4. Replies: 2
    Last Post: 06-25-2017, 01:30 PM
  5. Set Skype as default messaging client in Android Marshmallow
    By StanP50 in forum Android 6.0 Marshmallow
    Last Post: 06-25-2017, 09:37 AM
