1. snakedoctor42's Avatar
    I have an LG v20 and I keep getting the Feeling Lucky (from the bottom right corner of my screen) pop-up at random times. Any help how to get rid of it? If I can figure it out, I will attach a screenshot.
    07-17-2017 04:44 PM
  2. Javier P's Avatar
    Welcome to the forums. That looks similar to the swipe option included in ES File Explorer. If you have this app installed, disable it temporarily and see if the problem persists. Tell us how it goes for further assistance.
    Laura Knotek and Aquila like this.
    07-17-2017 04:50 PM
  3. Javier P's Avatar
    IIRC that menu pops up when you swipe up from the bottom right corner. Similar to the iswipe option in Clean Master and other CM apps.
    07-17-2017 04:53 PM
  4. Laura Knotek's Avatar
    Additionally I'd recommend using a different file manager app instead of ES File Explorer. Total Commander and Solid Explorer are both good and free of adware.
    Aquila likes this.
    07-17-2017 05:38 PM
  1. Lg V20 Bluetooth problems
    By Kyle Workman in forum LG V20
    Last Post: 12-05-2017, 01:08 AM
  2. Replies: 1
    Last Post: 07-18-2017, 08:41 PM
  3. LG g4 Screen Freeze Problem
    By AC Question in forum LG G4
    Last Post: 07-17-2017, 02:31 PM
  4. LG g4 Screen Freeze Problem
    Last Post: 07-17-2017, 09:51 AM
  5. GPS signal problems
    By GazzaC7 in forum Ask a Question
    Last Post: 07-16-2017, 04:24 AM
