1. A_nawaz's Avatar
    I updated my Samsung s7 edge to 7.0 at evening time and when i keep my mobile and turn off data as usual that time my charge was 78% when i woked up at 7 morning the battery was 49%.
    This is annoying completely and the performance of my phone is also slow according to previous version....
    Any solution?
    Or
    How to back on 6.0 ?
    11-18-2017 01:21 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! First, try wiping the cache partition: https://support.t-mobile.com/docs/DOC-28028
    If the battery drain continues, show us some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    11-18-2017 01:10 PM
  3. Rukbat's Avatar
    Look at the battery (in Settings) and see what's using so much of the battery. If it's Android System, Android OS or Google Services, it's because you updated the version of Android and it will settle down after a few days.
    To go back to 6.0, see [Samsung] How to flash Stock ROM via ODIN (you'll have to pick the correct firmware for your country for your carrier). You'll also have to back everything up (see Backing up an Android Device), because flashing new firmware wipes everything.
    11-18-2017 01:13 PM
  1. why android wear wont read my watch
    Last Post: 11-18-2017, 01:31 PM
  2. my BlackBerry q5 turneg off even it has 70% battery
    Last Post: 11-18-2017, 01:30 PM
  3. Why is the wal mart app update not compatible with s8
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 11-18-2017, 01:17 PM
  4. Why there are ads poping on my screen and disturbing?
    Last Post: 11-18-2017, 01:11 PM
  5. Why my phone stuck at the battry logo
    Last Post: 11-18-2017, 12:12 AM
