1. Tracey Hastings's Avatar
    Several times a day, the Play Store pops up the install page for Powerful Cleaner (boost and clean). I have Lookout, which says nothing is wrong. I have downloaded some others to scan and see if Lookout is missing something to no avail. Coincidentally (or not), this started the day after my 30 day free trial of Malwarebytes ended. I uninstalled it, no change. No rhyme or reason, it pops up very randomly and always the same app. I can be playing a game, watching YouTube (app, not browser), it makes no difference. Have had an OS security update recently which did not fix. Please, please make it stop. Details on my phone are below. Really trying to avoid a factory reset if possible. Thanks so much.
    Samsung Galaxy S7 Edge, Android 7.0
    Security patch applied 11/1/17
    Please let me know if there is any other info you need. Thanks.
    11-25-2017 03:41 PM
  2. Tim1954's Avatar
    Try going into settings, notifications and block play store.
    Boot up in safe mode and kill the app from there
    11-25-2017 10:24 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! I suspect adware that was installed alongside another app. Unfortunately, this means having to uninstall apps one by one until the problem goes away. Or doing a factory reset, and then reinstalling apps one by one to see if and when the problem comes back.
    See this guide for more info: http://forums.androidcentral.com/amb...p-removal.html
    11-25-2017 11:26 PM
  4. Dano1200r's Avatar
    Before you get as drastic as a factory reset, uninstall all suspect apps and clear the cache then reboot. Check under battery usage when this pop up occurs and you will see what app is open which could be causing this.
    B. Diddy likes this.
    11-26-2017 07:24 PM
  1. how can i make full backup for my note 3
    By moftakesegy in forum Samsung Galaxy Note 3
    Last Post: 11-26-2017, 10:57 AM
  2. My phone snoozes it's alarm when I pick it up or even before I touch it
    Last Post: 11-25-2017, 11:35 PM
  3. note 3 s pen works but touchscreen no longer rsponds to fingers. help pls.
    Last Post: 11-25-2017, 11:30 PM
  4. Play store installation speed is very slow
    Last Post: 11-25-2017, 11:28 PM
  5. Why is my voice mail unable to update so I can listen to my voice mails?
    Last Post: 11-25-2017, 11:27 PM
