1. Susan Rimes's Avatar
    N920VVRU3CQL4 Samsung Note 5
    Hi i have Samsung note 5 N920VVRU3CQL4 verizon changed to straittalk they said my phone compatible. Since I changed I have very slow if any internet the wifi icon as 1 dot and a ! Next to it . If I send a text message it goes to "pending status " i figured out the only way to get text sent us to dial any phone number! Then text is sent. I cant be on the phone and the internet at the same time (i could at verizon) also sometimes when sending text ..i get a message that says "No mobile network" .. My APN is greyed out. I think trying your APN is a good idea what do you think ? I should not have to dial my phone to any random phone number for the messages to get sent. I also read where the upgrade for the nougat has all these errors and that's why this is happening. But when I was on Verizon I didn't have all this problem I just used a ton of data and I can't afford Verizon and the update was either in January or December so I think it might be straight talk who doesn't know how to set up my phone on there Network. Thank you in advance any help would be greatly appreciated 😁 P.S I am not a tech savvy person but I know something is mot right I don't know if this matters but I had an update on 1/7/18 N920VVRU3CQL4(was still at verizon)
    and on 12/13/17 it says updated N920VVR53CQK1 is that right why are they two different numbers?
    02-05-2018 03:37 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Just to be sure -- enter your phone's IMEI into Straight Talk's compatibility checker and see if it comes up as compatible: https://forums.androidcentral.com/e?...token=bOAapDDp
    When you activated the phone with Straight Talk, is this how you did it?
    02-05-2018 11:34 PM
  3. Srimes1962's Avatar
    Yes I did verify my Samsung Note 5 was compatible and I did do the "Bring your own phone kit" and all what I wrote in my post is happening after verified and following instructions
    02-07-2018 05:27 PM
  4. Srimes1962's Avatar
    FIXED ! APN was at TRACFONE.VZWENTP thats wrong at least for my Samsung Note 5
    I changed that to ACC.TF.***********
    And everything works fine I can talk on the phone and be on the internet like I could before at Verizon I have four G my text messages send wow I impress myself
    B. Diddy and jericho.ar like this.
    02-07-2018 06:40 PM
  5. B. Diddy's Avatar
    Good job! Thanks for posting your solution -- hopefully it'll help someone else in the same situation.
    Did you create a new account on the forums? Were you having problems with your other account?
    jericho.ar likes this.
    02-07-2018 08:14 PM
  6. RealestRealist's Avatar
    I have the same problem ever since I switched from VZW prepaid to Straight Talk.. I usually get my texts but sometimes I don't until I make a telephone call out
    Also it's the same thing with no data while on a telephone call
    Did you actually enter ACC.TF.*********** or was that something other than asterisks, before? It won't let me edit any other field
    I am on TRACFONE.VZWENTP
    I tried taking the P off and putting it back on thinking that might update something
    One site said for ST there should be an MMSC entry, too, and I haven't got one
    MNC and MSC are 311 and 480
    Thanks !
    12-02-2018 02:05 AM
  7. RealestRealist's Avatar
    PS: It is a Verizon unlocked Samsung Note 5
    12-02-2018 02:05 AM
  8. RealestRealist's Avatar
    It said my post was marked as spam
    Can anyone see it ¿
    01-12-2019 12:18 PM
  1. Setting up my new s8 and now it’s asking for passcode? Haven’t set one up?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 02-06-2018, 07:49 AM
  2. Replies: 1
    Last Post: 02-06-2018, 12:33 AM
  3. Replies: 0
    Last Post: 02-05-2018, 03:30 PM
  4. Is it possible to recover a camera view I wanted to take a picture of?
    Last Post: 02-05-2018, 03:16 PM
  5. Setting up my new s8 and now it’s asking for passcode? Haven’t set one up?
    Last Post: 02-05-2018, 03:10 PM
