Android Nougat. LG Aristo phone I've had for several months. Carrier is T-Mobile.
All of a sudden today I have to disable wifi, bluetooth, and mobile data in order to make an outgoing call. If any of those are enabled the call is blocked. Disabling them allows the call to go through, I don't even have to dial the number again, it's like a blocking thread was destroyed. Wifi calling and VoLTE are both disabled.
This "disable everything" solution came from T-Mobile support like it's something they've encountered before. They won't tell me what the problem is or how to fix. I call BS. Anybody know of a fix?
Googling this issue is ridiculous, the results are everything but what I'm looking for. Yes, I'm so old I remember when Google gave you the answers you were looking for without any AI "I know more than you do" garbage.
Thank you in advance.
