1. patches223's Avatar
    Android Nougat. LG Aristo phone I've had for several months. Carrier is T-Mobile.
    All of a sudden today I have to disable wifi, bluetooth, and mobile data in order to make an outgoing call. If any of those are enabled the call is blocked. Disabling them allows the call to go through, I don't even have to dial the number again, it's like a blocking thread was destroyed. Wifi calling and VoLTE are both disabled.
    This "disable everything" solution came from T-Mobile support like it's something they've encountered before. They won't tell me what the problem is or how to fix. I call BS. Anybody know of a fix?
    Googling this issue is ridiculous, the results are everything but what I'm looking for. Yes, I'm so old I remember when Google gave you the answers you were looking for without any AI "I know more than you do" garbage.
    Thank you in advance.
    02-21-2018 09:34 PM
  2. UglyStuff's Avatar
    Maybe disabling VoLTE did more bad than good: after all, VoLTE means "Voice Over LTE", and relies on 4G to send and receive phone calls, so disabling it means that your phone's 4G will only be used to send and receive data, not phone calls.
    In my case, it's often the opposite that happens (and I do have VoLTE enabled, though my carrier doesn't yet offer it): when someone calls me, it interrupts the data stream, and I lose connectivity when I'm using the phone as a hotspot.
    Are you sure it has nothing to do with your calling plan?
    02-22-2018 04:13 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Go to Settings>Mobile Networks>Preferred Network Type. Is it set to include 2G/3G as well, and not just 4G? If the phone is set to only use 4G, and you turned off VoLTE, then it can't do both voice and data at the same time.
    02-22-2018 07:09 PM
  1. LG V30 doesn't have LG Smartworld and doesn't work
    By Android Central Question in forum LG V30
    Last Post: 04-12-2018, 11:44 AM
  2. How to route audo through the USB-C port
    By bryan10983 in forum LG G6
    Last Post: 02-24-2018, 11:36 PM
  3. WTS: New in box Sprint GS8
    By rockyjay in forum The Marketplace - Buy, Sell & Trade
    Last Post: 02-24-2018, 11:45 AM
  4. No messages text from pixel xl to older iPhone
    Last Post: 02-23-2018, 11:28 PM
  5. Why is all the data on my portable SD card gone after updating?
    Last Post: 02-22-2018, 07:10 PM
