1. mvasquez009's Avatar
    I'm currently using gsam battery monitor on my Google pixel XL. There are times I do not use my phone for an hour or so and upon checking my battery stats in the phones settings the graph is showing a steady decline ...it never levels off flat to indicate it had went into a deep doze session. So I downloaded gsam and it is showing that it enters light doze but never a deep doze ..any clue what can be causing this ? I'll try to include a screenshot
    05-30-2017 02:36 PM
  2. mvasquez009's Avatar
    Second screenshot
    05-30-2017 02:54 PM
  3. dropoffmapdeveloper001's Avatar
    Yes, there must be an app the you have installed that is keeping open a wakelock.
    Try going into the Usage details for each top consumer and checking the Keep Awake. It would be easiest to do this once the phone is fully charged. Then the battery stats reset.
    05-31-2017 12:26 AM
  1. Why is my phone saying no APN specified on the device
    Last Post: 05-30-2017, 03:00 PM
  2. Replies: 2
    Last Post: 05-30-2017, 02:05 PM
  3. Replies: 1
    Last Post: 05-30-2017, 01:36 PM
  4. Unwanted Words Inserted Into Google Search
    Last Post: 05-30-2017, 01:26 PM
  5. Facebook is not opening on My Android mobile
    Last Post: 05-30-2017, 01:17 PM
