1. flipbeats's Avatar
    Got a new car with android auto. I was running android O. Bluetooth connected, received messages/ calls/ but the music wouldn't work. it would display and play but no sound would come out. Tried another phone with 7.1.2 ( latest release of public OS) and it worked perfectly fine. Just wanted to give everyone a heads, just in case you run into this situation.
    07-04-2017 12:19 PM
  2. jonasmyst's Avatar
    I had this same issue. I had to go into the specific Bluetooth device's settings and uncheck the High Quality AAC setting. Started working after then and is likely because that relates to something Sony only at this point.
    07-06-2017 04:01 PM
  1. Replies: 1
    Last Post: 07-05-2017, 04:54 PM
  2. Why did Android screw up Outlook contacts ?
    Last Post: 07-04-2017, 10:37 AM
  3. Replies: 0
    Last Post: 07-04-2017, 10:30 AM
  4. Sound only coming through right side
    Last Post: 07-04-2017, 09:40 AM
  5. Replies: 0
    Last Post: 07-04-2017, 09:06 AM
