1. cumulations's Avatar
    Do You Think so that Google has made so many changes in Oreo? For normal User, its seems to be normal use of Noughat and Oreo both work same.
    What is your opinion?
    11-03-2017 02:23 AM
  2. mhinc's Avatar
    Quite a few new features.
    https://android.gadgethacks.com/news...-oreo-0176682/
    11-03-2017 02:28 AM
  3. LeoRex's Avatar
    What you see isn't always what you get. Visuals in the UI are just a small piece of the puzzle. One such example is the new autofill API that allows password managers like Lastpass to fill in login screens without using the accessibility service (which they won't be able to use anymore at some point by the way).
    There are enhancements to power consumption, etc... Pretty much every system has changed.
    11-12-2017 09:38 PM
  1. YouTub black screen android
    Last Post: 11-03-2017, 07:19 PM
  2. Android device keeps losing internet connection while other devices are fine
    Last Post: 11-03-2017, 12:38 PM
  3. My location in my android is wrong
    Last Post: 11-03-2017, 10:54 AM
  4. Post a picture of your home screen and icons
    By Dconn1975 in forum Honor 8
    Last Post: 11-03-2017, 07:36 AM
  5. oreo beta for Indian s8 plus?
    By msingh48 in forum Samsung Galaxy S8 & S8+
    Last Post: 11-03-2017, 06:22 AM
