1. belanger's Avatar
    I'm running 8.1 on my Google Pixel XL and ever since the 8.0 upgrade, I've noticed that the setting that lets one disable the warning about a certain app, in my case Should I Answer?, no longer works and there's a constant Notification that the app is using battery. Anyone aware of how to fix this or do I have to wait for Google?
    Thanks,
    MB
    01-22-2018 06:25 PM
  1. You need to set a lock screen PIN before you can use Credential Storage???
    Last Post: 01-24-2018, 05:59 AM
  2. LI-ION batterys Toxicity/trouble
    By bruxo200 in forum LG G2
    Last Post: 01-23-2018, 12:57 PM
  3. Why is the internal keyboard not popping up?
    Last Post: 01-23-2018, 05:36 AM
  4. Why am I not able to set music as my text message notification?
    By Latisha Lucas in forum Ask a Question
    Last Post: 01-23-2018, 02:02 AM
  5. How do you reset a galaxy core prime that you do not know the password for
    Last Post: 01-22-2018, 04:38 PM
