1. Cos K's Avatar
    After the system update to Android 8.0, the notification sound setting for my apps has been set to default notification sound. I tried to reset the notification sound of each app to its previous ringtone sound but it keeps setting to the system default setting. Now all the apps have the same notification sound & can't differentiate which notification app is that. How can I reset my different app notification sound to its previous ringtone sound before the update?
    02-18-2018 02:53 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! For which phone?
    02-19-2018 03:58 AM
  3. Cosklu's Avatar
    Hello Diddy. Thanks for your reply. It's Nokia 5.
    02-23-2018 03:15 AM
  4. chanchan05's Avatar
    Since it's after an update I'd look into wiping the system cache.
    B. Diddy and Laura Knotek like this.
    02-23-2018 03:16 AM
  5. Cosklu's Avatar
    So any steps I can do on my side?
    02-23-2018 03:23 AM
  6. chanchan05's Avatar
    As I said. Wipe the system cache on your phone. It won't take more than 1min. The exact way to get to the menu is different for every manufacturer though. Never had a Nokia Android phone.
    02-23-2018 03:40 AM
  7. chanchan05's Avatar
    Here's a video.
    The only difference is you select wipe cache then reboot. Do not reset.
    02-23-2018 03:43 AM
  8. Cosklu's Avatar
    Hi again. I tried though & what appeared on the screen was an android icon with the words "No command" instead of the android recovery as shown on the video screen. Is something wrong with my phone?
    02-24-2018 01:34 AM
  9. chanchan05's Avatar
    Well no. At least that shows up when I do it on a Samsung, then I just wait a few seconds and the menu shows up.
    02-24-2018 02:16 AM
  1. Replies: 2
    Last Post: 10-23-2018, 06:10 PM
  2. How do i unblock my notifications and my tabs will not show up on this device
    Last Post: 04-30-2018, 05:39 AM
  3. Light Flow & Phone Notification Both Go Off
    By EddieLols in forum Android Apps
    Last Post: 02-19-2018, 03:54 PM
  4. Replies: 2
    Last Post: 02-18-2018, 12:33 AM
  5. Why i can't receive sound when new messages coming on Samsung s8
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 02-17-2018, 09:19 AM
